Drive By Wire conversion.
Old 08-07-2007, 09:48 PM
truckmann's Avatar
I would have to agree on the cam... It's really overkill for stock heads. You might be better off selling it and finding something more on the order of a tr224, vinci trucker cam or similar. Something with under .600 of lift.
Old 08-07-2007, 09:49 PM
RandomHero's Avatar
exactly man. People forget that the fastest n/a 5.3L runs a cam with .551 lift
EDIT-The stock 5.3L heads begin to max out at .500 lift(that's not a typo) and even if you get new heads, the intake maxes out at about .600 lift. Both don't flow very well, but the stock 753(or whatever they're called) heads are ****.
usarmyman's Avatar
Thanks for the find, I will check them out.
Old 08-07-2007, 09:52 PM
usarmyman's Avatar
The heads are stage1, I don't think they are stock, could be wrong.
Old 08-07-2007, 09:55 PM
RandomHero's Avatar
I'll try and hold my tongue man, but stage 1 doesn't mean anything. Who did the heads and do they have flow numbers. I could post some stock head flow charts that would make some guys on here cry
99Silver6.0's Avatar
Holy **** that cam has alot of lift. Hope this isnt a DD!! And you have a stall!! And a good tuner!!
Old 08-07-2007, 09:57 PM
usarmyman's Avatar
DD yes and it is a manual.
Old 08-08-2007, 05:27 PM
Mr. Obvious
nightrunner's Avatar
if you keep that cam you will probably end up having to swap to hydroboost brakes
Old 08-08-2007, 05:29 PM
silveradokidd_4518's Avatar
ho...ly...****...thats a big cam man for a DD...like a couple others have said, you might wanna look into some heads for that thing. dual springs as well...
Old 08-08-2007, 07:39 PM
dirt track racer 81's Avatar
you will need a complete wiring harness for a 5.3..cut the injectors leads off and put on some bosch leads from the parts store..28 lbs ls1 injectors should work..you for the year model you are your probably returnless fuel system so you can make ls1 fuel rails work..for that cam id run a fast 90/90 intake and tb..wich is cable drivin..this gonna be a 6.0 or 5.3??
Quick Reply: Drive By Wire conversion.
