Dropping Oil pan, need new gasket?
I have all the parts & tools I need for my cam swap, including new oil pump and timing chain and gaskets, EXCEPT for a new oil pan gasket.
It was suggested to me to go ahead and drop the oil pan completely instead of just lowering a few inches, to change out the oil pump. When I drop the pan, do I need to replace the oil pan gasket, Fel-Pro part number OS30693R? Haynes manual says to drill the gasket rivets and replace with a new gasket, no rivets needed.
Just want to make sure I get things inline before I dive in. Because this is my DD, I can't afford to be down for more than a weekend!
Thanks guys..
Thanks guys..
Baltimore Whore
You can get away with reusing the old gasket, but you need to be careful you do not bend it or kink it. Alot of the seals on LS engines are reusable, as they are steel with a O-ring style gasket.
If you go to the trouble of dropping the pan I wouldn't put it back on without a new gasket. I even had to disconnect the motor mounts to drop my pan and I have a 6" suspension and 3" body lift. Freaking pain dude.
