Dry Shot Harmful to Stock Engine?
#41
Originally Posted by blowinbyyou
I know you guys might be right on the whole spraying before the MAF thing. But my friend has been spraying a 100 dry shot right infront of the throttle body for like 2 years now. An his struck is still running great. I thought it would of messed up something by now. An he never even hears an denotaton either. So I dont really know what to say.
Dry nitrous after the MAF. In this case the nitrous is injected in a manor that does not require the air meter to compensate. In most cases, engine vaccum or tps is used to actuate a fuel boosting system. On a bypassing fuel system the vacuum circuit is usually controlling the fuel pressure regulator and under WOT boosts fuel pressure to a determined value to match nitrous flow. Some systems use tps and o2 readings to activate higher injector cycle time. In either case the injectors are directly influenced into flowing more fuel outside of the air meter's reading.
#43
to what Oxidizr just said...don't people read? If you don't have the necessary additional fuel to go with the nitrous, you will destroy your engine.
ARC
57
02-21-2022 10:54 AM
