DTHPROOF's BuildThread
#31
According to an old thread I found, my LQ4 with milled (0.30") 243's should be 11:1 CR. I hope it turns out strong. I also dug up the cam info and updated the first post. The cam is an Advanced Inductions custom grind
234/238
.629 .630
112+5 LSA
My wife is picking up a new timing cover gasket from the dealership this afternoon and I'm going to paint my motor tonight (weather permitting) and take some pics. Thanks for looking.
-Josh
234/238
.629 .630
112+5 LSA
-Josh
#32
13 Second Truck Club
it wont be 11.1cr using stock gaskets more like 10.46to1give or take .1
thats assuming .030 will remove 4cc from the chamber giving you a 60cc chamber on the 243s
just bolting stock 243s on a lq4 will get right at 10to1 CR using stock head gaskets
#34
10 Second Club
Be careful what size chambers you mill the heads down to Josh. I had flycut pistons so I was able to get 61cc out of my old AI 243s to prevent ptv issues.
With my old 230/236 cam and 63cc chambers with stock LS1 pistons I had slight nicking of the intake valve on the pistons which eventually blew a hole in em'.
#38
10 Second Club
However, in Josh's situation, AI spec'ed the cam so when he gets the heads done by them they can set him up perfectly for chamber size and milling and even with proper pushrod length to use.
#39
Yesterday was a long day! Pics added in the first page. We got my old oil pan cleaned out from all the chunks of ring and piston, assembled and painted the motor, and dropped in. I added a few pics on the first page. We went to fire it last night and the crank position sensor wasn't plugged in so the coils had no fire. Got that plugged up and still no fire. HP tuners still says 'crank position circuit' so we're switching out to another crank position sensor and trying again. Big thanks to Jamie (the guy in my engine bay) and our good buddy Jason (fastjweb). You guys are a blessing.
Vids coming as it starts!
#40
Here's a brief vid with a WOO WOO for the PT.net sticker! lol
http://www.youtube.com/watch?v=AkRIcPwJOFQ
