Dynatech header install questions...
The only boot that wants to touch is the rearmost one on the drivers side there... (sorry, I forget cylinder numbering).
I have my little bracket with the hole for the wire tie angled JUST right, to hold the boot about 1/8" from each primary. It was a PITA to get set correctly.
I can get some pictures if you want? Give me a few minutes...
Its amazing at how crappy your exhaust can sound with a few minor leaks.
My exhaust has leaks when its cold. Once the pipes get hot, everything cinches up tight and it sounds better. On cold mornings, with the higher idle, rich mixture because of the cam, and the leaking exhaust, my truck really sounds bad. Once it warms up to operating temps, its all good.
Good wire ties. I thought of that for mine, but I didn't want to take a chance on them melting, for any reason. That's why I just shaped my brackets to hold back the wires, themselves.
Looks great. Glad you got everything worked out on it.
Originally Posted by snakeoiler
Wow, everyone of the boots on mine laid right on the primaries. Damn boots are so freakin' long.
I hear that the metal shields on the stock wires will fit on the MSD's... Would that have helped you much?
Mangled - I paid $800 (shipped) for them used... I think they typically go for 1100-1200 new, with cats.
What do you guys think.... everything tight, or am I still leaking?
http://yo_marc.tripod.com/video/header.mp3 (thanks John)
