Dynatech Longtube Header Package worth the money?
I have the Dynatechs on my SS, They bolt right up.It was the easiest header install I have ever done. The only thing is they are not 50 state legal. I have heard that they will pass a sniffer test though. I have the whole thing cats and all.
Whether it's worth it or not is a bit tough to say. I bought mine when they were on sale. I dropped 3 tenths with the Supermaxx and magnaflow combo, and I'm sure it has more it in if I could just tune the A/F ratio.
I bought them over the other LT's basically because my factory exhaust is untouched. I can bolt it back in anytime, just incase I get crazy and go turbo some day.
Digging this one up, sorry, just adding my 2 cents.
I was pretty reluctant with spending the cash too - I got lucky, I found a low mile set that came off an '04 SS like mine. Got them for $800, cats and all. I knew if they fit 'that' SS, they should fit mine. They do - perfectly.
Those few drivers side plug wires are definitely a "gotcha". I got pretty annoyed at myself for not realizing that until I was near the final stages of the install, and realized I had a big problem with the wires heavily touching the primaries. I fabbed up some craptastic sheet metal tabs that got bolted to the header-to-head bolts. I then used simple wire-ties to secure the wires to them, and out of danger.
Pic 1
Pic 2
I had to trim the extra threads hanging off the shaft bolt, which was nothing at all.
I love the headers. Performance added from ~1,100-1,200rpm and up. Definite improvement in highway speed, overdrive, roll-on power. Very noticeable midrange increase.
Pic 1
Pic 2
Pic 1
Pic 2
Pic 1
Pic 2
No - slightly worse than before, but not that bad at all.
The passenger side is still a piece of cake. The drivers is the one that's a little harder because of that kinked up primary, but I think you can actually see the plug holes in the head now with the headers. I remember using a 4" and 6" extention, and POSSIBLY one of those small wobble extentions to get the plugs in.
I can go look at them tonight and see how things look.
I know I had to use a wobbler to get the torque wrench on the header-to-head bolts, maybe that's what i was thinking of.
These are our favorite headers to install...the easiest to install. High quality, and makes tremendous power. Id definitly recommend them. We do them on almost every radix install that comes through here.
