dynatech or stainless works header install
Does anyone know if the dynatech or stainless works headers are a direct bolt-on to the existing factory pipes in front of the cats? I'll cut the stock pipe in front of the cats, but i dont want to have to do any welding or bending.
05GMCL33,
So your saying that there's not any bending required of the pipes that mate to the ends of the headers? The pipes past the collectors slide right into the factory pipes?
Do they come with clamps for the pipes? Do you have these on your truck?
I've been told by dynatech that the full system will not work on my truck (2500HD 6.0 liter 4wd). But they said the headers will fit. I didnt ask them if the "header only" install was a "FULL" bolt-on install. By hearing that from dynatech, I figured that meant that anything (y-pipe) past the headers on their full system would not work on my truck. Currently, everything is stock from the manifolds to front of cat-back, 2 cats, 2 pipes.
1slow4.8,
I'm not sure if the y-pipe tucks above the frame, i believe that it does tho. The cats are up inline with the framerail, but i dont remember if the pipe in front of the cats dips lower or not.
