Dynatech Supermaxx
Originally Posted by O3GMC
Not sure how much it costs, and yes mine are stained pretty good
Did the headers on your mustang "blue" (turn gold/blue) ? Being stainless, mine blued almost immediately but I've always wondered how ceramic coating affects this.
Adkoonerstrator
I cleaned the hell outta my dynatechs and they still got all stained up. I really don't care but, they look bad now. I would have them coated or recommend it if I ever sell them.
The only real issue I had was getting spark plug wires to fit on the #5 and #7 plugs. The wires they sent in the package didn't seem to fit AT ALL. I have some longer truck wires on those two plugs that work good.
12 Second Club
You guys received wires with your headers as part of the kit? Hmmm, I didn't. No matter.
I installed mine in August and my only fitment issue is with the driver side pipe where it makes the 90* turn after the cat. I have about 1/8" clearance from the trans crossmember. It rattles about 20% of the time, but not that bad even when it does. Mine have turned a slight golden color, but it seems to have colored less where the pipes were polished better.
Yeah, the MSD's they sent with the kit just barely hang onto the plug. They told me they stopped sending those and started using heat sheild covers. They sent me out a pair and it seems to work ok, but having the wire rest on the header tube is making it brittle....I'll be looking at new wires soon.
12 Second Club
I've been looking at Magnacore wires, havent decided though
Yes y pipe is two peice, I have mine tack welded by the pass.side cat b/c it seemed to be slipping some, but yes it seals fine with the supplied clamps.
