E-Fan/Over Heating Issue?
Old 06-22-2008, 03:08 PM
KDT
KDT's Avatar
Default E-Fan/Over Heating Issue?
I just got done installing 05 e-fans on my wifes 04 Yukon Denali. It's about 85ish here in Chicago today. TOOk the truck out for about 30 minutes and thought i wasn't going to make it home before it was almost in the red on the temp gauge? I have a harness made from Caspers Electronics, it only has two relays? I was really looking forward to doing this, the install was perfect. Now i'm scared to run them so i pit back the clutch fan. You could really tell a difference with the e-fans in as far a performance. I want to run these fans but i don't need to be worried 24/7 driving the truck! Any thoughts whats going on here? Am i missing something stupid? I hope it just a relay issue?
Old 06-22-2008, 04:12 PM
KDT
KDT's Avatar
I will also add that my ac was very poor and the fans were very loud. When i did a search it seems that the fan's are not that loud? Again these or brand new o.e.m. gm fans! The harness that i got from Caspers was built for a trailblazer ss e-fan conversion. Don't know if this is the whole issue or not? I heard that the Nelson Harness wasn't that good for the 6.0? Hoping this will pan out and i can get this fixed?
Old 06-22-2008, 04:48 PM
2004SSS's Avatar
seee if the fans are running backwards, you may have the postitve and negative on backwards, make sure they are pulling through the radiator and not pushing air into it., if you have a grill on the truck it should be nice and cool when they are on.
Old 06-22-2008, 06:51 PM
chriswtx's Avatar
I am woking on this today on my 04' Denali. Haven't ran the truck yet, but my Nelson harness has 3 relays on it...I'll know within a few hours if there are cooling issues...Also did a 160* thermostat while I was at it..
Old 06-22-2008, 07:46 PM
nonnieselman's Avatar
its been 100* here and ive never had a issue with the stock Tstat or the rigged 170* Tstat..
Ill be willing to be the Polarity is backwards like he said..
I had a 3 bank relay setup to the A/C clutch switch.. Got tired of the fan kicking on and off so i ran that wire to a switch in the cab..
PCM tells the fans to come on low at 173 and off at 172
I can flip the switch and one fan comes on high, and then flip the other switch and both come on high..
Old 06-22-2008, 07:49 PM
RandomHero's Avatar
I live in Austin. It's 100 here every single day. I've been running efans for a year now with no heating issues. You definitely have something wrong. Especially if you're using the bigger 34" fans.
Old 06-22-2008, 07:55 PM
im using old 1994 LT1 Efans with new motors.
Old 06-22-2008, 08:17 PM
chriswtx's Avatar
Just finished mine. Very quiet, set them with EFI live to come on at 195 and off at 185. Working like a charm. Bet yours are running backwards...
Old 06-22-2008, 08:50 PM
KDT
KDT's Avatar
Thanks for the reply! Love your vette! Looks bad ***! Nice stance! What size tire's are out back? I got a 430rwhp 04 GTO 6sp.
Old 06-22-2008, 09:05 PM
chriswtx's Avatar
only 295s out back right now 19x11.5 wheels. Going to switch to 345s with 19x13 wheels later this year..
Quick Reply: E-Fan/Over Heating Issue?
