E-fan setup??
Old 11-14-2004, 06:30 AM
  #21
Formerly one92rs
one03sierra's Avatar
Talking
yes they free up hp. there is only amp draw on the alt that the engine is pulling. no clutch. no the predator will not set them up. you will have to get a custom tune or by edit or hp tuners to get it done.
Old 11-14-2004, 03:59 PM
  #22
bodyguard6799's Avatar
This is the last time I promise!! When you had the Derale setup how did you hook the fans to the wires?? Did you have the factory pigtails b/c I didnt get that w/ the fans. THANKS!!
Old 11-14-2004, 04:04 PM
  #23
Formerly one92rs
Talking
yes sir i ordered some pigtails for them.
Old 11-14-2004, 05:48 PM
  #24
Where did you get them from? Because I went to the dealer and the only way they have it is the whole harness.
Old 11-14-2004, 05:52 PM
  #25
SnakeOiler's Avatar
Are those 280 or 150 series Metripak connectors? I can hook you up with either one using 12 AWG wire - just specify the length.
Old 11-14-2004, 05:55 PM
  #26
Sorry, I forgot you didnt have the LS1 fans!!
Old 11-14-2004, 10:21 PM
  #27
Formerly one92rs
Talking
i used to have the fans. i ordered them from a used parts place
Old 11-16-2004, 10:07 AM
  #28
02denali, did you have the pipe thread or radiator probe setup?? And is that used parts place you got the pigtails form online?? THANKS!!
Old 11-16-2004, 10:14 AM
  #29
marc_w's Avatar
Originally Posted by 02denali
i went to the dccontroller since it didnt turn them on at 100% ever. but i have since went to a nelson harness and they are at the 60% and 100% cycle again, the dc controller is a good piece but it is very delicate. i think the harness i have now will work just fine. it is wired up the same as the ls1's.
What happened to your DCC controller??
I'm still running my smaller 35A one. Mine has been running flawlessly. I broke the temp sensor when swapping cams this last time, so I had to replace that... but that was obviously my fault.
Old 11-18-2004, 10:26 AM
  #30
02denali, I was looking at the derale fan control and it downt come with the relay for the A/C. Where do I get one, what amp, do you hav a p/n?? THANKS!!
Quick Reply: E-fan setup??
