E-Fans
Old 03-02-2006 | 06:05 AM
  #21
SnakeOiler's Avatar
Originally Posted by Pjstucn
im finding new problems, ive had some people tell me the tgruck will burn uot the ls1 fans due to havein g to do more cooling then for the cars,
You should be fine
and flex=a=lits e fans for our trucks only fit 34 inch rads wtf, is the 5.3 rad bigger the the 4.8? from 03-04
As far as I know the 03-up are the same as the 99-02 for radiators. FAL makes the 292 for the 27" radiator and the 282 for the 34" radiator.
Old 03-02-2006 | 07:44 AM
  #22
mjustmike's Avatar
Originally Posted by SnakeOiler
You should be fine
This might be a stupid question but are you measuring the actual core area or the overall width? I have an '04 Sierra with a 5.3 and the overall radiator width is just over 34".
I'd like to get some electric fans also but don't want to get into a bunch of headaches by doing it wrong and having to "adjust".
Thanks in advance!!
Old 03-02-2006 | 08:02 AM
  #23
SBChvy's Avatar
you measure just the cooling area-and yes the 5.3 only has a 27" radiator. The 34" radiators are found in bigger trucks, tahoes, and suburbans.
Old 03-02-2006 | 08:08 AM
  #24
dkota196800's Avatar
[QUOTE=white1]I bought some aluminum, Ill try to get some pics this weekend. Btw anyone that needs a harness, PM me. [/QUOTE
That would be great, thanks.
Old 03-29-2006 | 11:33 AM
  #25
Whippled 496's Avatar
I dont completely understand the electrical aspect of the E-fan install. I have the bigger radiator, so i could use the LS-1 fan or 05 fan, but how does it wire up to the PCM? Do i have to tap into something?
Old 03-29-2006 | 11:54 AM
  #26
white1's Avatar
Yea, you use some relays, tap into a hot, and a ground. Then tap into the A/C compressor wire, and pin 42 in th ePCM, and you have to have the fans turned on in the PCM. If you need a harness for the LS1/LT1 fans, PM me.
Old 03-29-2006 | 12:07 PM
  #27
cool, thanks.
Old 03-29-2006 | 04:52 PM
  #28
LJ93Z28GM's Avatar
http://bertok.us/agreif/fans/fanstech.htm
Old 03-29-2006 | 07:42 PM
  #29
8MC's Avatar
8MC
I would also recommend using at least a 145 amp alternator to compensate for the power draw. You will also need a longer serpentine belt(same one found on the Denali)
thunder550
10-08-2015 04:53 PM
old motorhead
09-29-2015 08:22 PM
lycominghunter
26
09-25-2015 07:50 AM
2000_Silverado_SS
09-18-2004 09:02 AM
Quick Reply: E-Fans
