E-fans dyno #'s?
E-fans dyno #'s?
With all the talk about electric fans, I'm kind of curious if anyone has dyno #'s to show how much power is gained. I remember years ago CarCraft or HotRod did a engine dyno test with about 6 different flex-fans and clutch fans, but I don't remember the #'s.
Originally Posted by BlownChevy
you should see quite a bit....17 or so hp.
Philip S.
Actually I saw 17 HP on mine.......Before and after dynos. Only change was the Fans.
Philip S.
Originally Posted by BigBlockChev572
That's probably because the dyno with mechanical fans the clutch was engaged.
Philip S.
Philip S.
And? Still a 17 hp gain......
In the summer the fan is like a parachute on the motor....Bottom line the fans free up HP.
17hp is 17hp ... I don't know many more ways to look at that.
Both of you guys are right though. I think unlocked, it's not much problem, but sitting in a staging lane it will sure get hot and lock up. I think it might be a little more than your thinking though.
Just curious.
Philip S.
