E-fans , Enough Cfm??
Old 08-08-2005, 01:36 PM
getchusum99's Avatar
Default E-fans , Enough Cfm??
I Was Lookin At Some Lt1 Fans On Ebay And It Said Not For Full Size Truck Applications, Because The Radiators Are Bigger And Require More Cfm And The Motors On These Fans Wont Get The Job Done. Is This True? I Know Alot Of Yall Have Em In Yalls Trucks, And I Want Some Also.thanks
Old 08-08-2005, 01:37 PM
OKLAGMCRUISER's Avatar
BS...It's a ploy to insure liability for the seller becasue they don't know any better.
Old 08-08-2005, 02:09 PM
Thats What I Figured, Thanks . Are The E-fans Worth It??
Old 08-08-2005, 02:14 PM
colder a/c is worth the money to me...and not having the clutch fan engaging at almost every stoplight in town...there's gotta be an increase in mpg...jury is still out for me though. I just installed mine.
Pat
Old 08-08-2005, 02:17 PM
chevyerett's Avatar
I like mine. Cheap, more mpg, more power, what more could you ask for?
Old 08-08-2005, 04:24 PM
FormerVendor
KLUG'S SS's Avatar
I just installed my 05 GM efans just the other day and I already notice the better mileage and the throttle response seems to be better also, I think efans are definitely worth it.
Old 08-08-2005, 04:50 PM
therock's Avatar
Default If You Are Gonna Tow...
...I would go 05 or Flex-A-Lites and your choice of controler. The FAL's really move some air but draw more on the ALT.
Old 08-08-2005, 04:53 PM
save the money and buy a set of used ls1 fans online...get a harness from nelson and get your pcm programmed OR get a vsc.
Old 08-23-2005, 09:02 AM
timvan's Avatar
will this work on a 6.0L ??
dual electric fans from a 2001 Camaro SS. This item will fit 98-02 LS1/V8/V6 Camaro, Firebird and Trans Am models. This is also a perfect upgrade for those looking for a replacement or doing a motor swap into their hot rod.
Old 08-23-2005, 10:09 AM
the underhood temps are crazy on f-bodies. if the fans can manage to keep those things cool, i can guarantee you that it can keep a truck cool.
trav
Quick Reply: E-fans , Enough Cfm??
