e-fans installed
e-fans installed
Finally got my LS1 fans in after getting my harness from White1 a while back. What would make the fans run all the time? They run on low all the time and on high when I click on the AC.
I did drive it for a day without the pin 42 hooked up and the fans did not work until I turned the AC on which triggered one to turn on high. Now with pin 42 hooked up both run on low as soon as I start the engine, then will kick into high when I turn AC on.
Pin 42 is the slot you need to install the pin from the harness to. you need to double check that you installed it to Pin 42 of the BLUE harness on the PCM. Make sure that it is fully seated (it will click when it seats), you may need to take a paperclip or fine screwdriver to push it in all the way. As stated above the pin is receiving an ignition on ground. You may wish to talk to Jessie about it and see what he set your fans to.
It is installed correctly, got an email out to Jesse, see what he says.
I broke the pin that came on the white1 harness and could not find them anywhere, so I soldered it back together.
