e-fans question?
PT's Slowest Truck
Originally Posted by SSlow 4.8
does that nelson harness work with fans that have a single speed? i just have a junkyard fan that is really strong, has 2 wires.. been needing to get that thing wired to the computer, if i tell nelson what ive got, they can customize it right?
PT's Slowest Truck
Just an example, my truck is a 99 that originally had a clutch fan, and I now run efans that are controlled by the PCM...as well as turning on when the ac compressor engages, thanks to a wire going to the compressor clutch B+ that goes to a relay in my Nelson harness.
PT's Slowest Truck
They don't work on their own, you either have to tune for them, run a manual switch, or use a temp probe that goes into the radiator fins. The temps probes are prone to failure though, so I recommend against that method. PCM controlled efans is by far the best method, and you can still have a manual switch if you want.
TAPyvehc93
09-12-2015 08:19 PM
carid
09-10-2015 09:07 AM
