Eaton Install Tech Article
Hope it helps you if you need it. Let me know if you have any questions.
http://james.jaguar.net/agreif/eaton/eatontech.htm
Andrew
Andrew
Andrew
Andrew
Originally Posted by KeukaZ71
thanks andrew. looks like the removal of the carrier was a PITA. also looked like you ran into a few unexpected obstacles too (visits to shops and garages). i bet the 2nd time around will be a piece of cake. i still have a few questions of course. what is the difference between bearing cups and bearing races?
