Eaton Posi help ...
Flyer, this is the center pin Hitman is refering to. There will be a set screw about where my right index finger is in the pic. Pull that pin out, push the axles in, pull off teh c-clips and pull out the axles. If you havent already taken the caliper brackets off, find you a nice piece of pipe to use as a cheater to break the bolts loose cause they are tough with the 2 lbs of yellow locktite GM puts on them.
GOTYA ... thanks BigKid. I will give that a shot tonite. I broke a 3/8" ratchet on those damn caliper bolts. Those things are a BITCH! I only did one side. I almost ate a piece of brake rotor when the rathcet let loose so I thought I would take a break from them.
Will I need to take that fat *** pin out of the Eaton as well?
I was looking for something small on the inside of the differential I was suppose to take out.
Is there anything special I need to get those damned clips off? I can't get them to budge. Do any of the guts come out of the diff once the pin comes out?
I'm guessing I pull the clips out from the side shown in the picture?
http://www.woracing.com/truck/G80/100_0998.JPG
I feel like a dope ... this thing is kicking my rear!
OK ... I've goten this far. The brakes are completely off. The bare axle hubs are showing, even the rotors are gone. I can push the axles in and see the clips. I can't get the damn things to come off though. That silver block in the middle seems to be in the way. I can't get it out, and I can't see how it would come out. I got the pin out and it will move around, but I can't get anything to come out.
I took a screwindriver after the clips to try and pry them off ... they didn't even budge! I think if I could at least get the differential out .. I could get it back in. The new one doesn't have all that added **** in the front of it.
On a side note ... I can see where some wtress has been put on that pin that goes through the middle. It has some nice scars on it. I see some hard dings on the gears too which tells me that they have seen a good bit of stress too, I'm guessing from the G80 being a little screwy with it's lockup and such.
i could help you more with a better pic of the other side. but tell me this the screw/pin came out on the other side (or the photo i did not wright on). if so the center piece will slide out from that side. on my buddies car i actualy had to take a hammert after the center piece because the rearend was trashed. i just taped on it to get it to slide out. i am prety sure it will not slide completely out just enough to let the axles slide in.
this sux when i have some good resources but none of them are in front of me.
get me a better pic and hopefully i can help some more.
