Ebay Header Help !
PT's Slowest Truck
Are the sensors still plugged in? Sometimes it takes a while to trip a code. If they're completely unplugged and the light still isn't coming on, and the PCM hasn't been tuned, then I'm baffled.
!!UPDATE!!
SES light is now on !
Truck is now sputtering under load ?
I'm sure this has to do with the EGR ?
Also Noticed a ticking noise under drivers side , it seems that its rubbing front drive shaft , i had to heat and dimple for clearance .
So can someone explain to me what a tune will do ? Does just cover up the EGR an O2 codes ? or does it actually adjust the computer for proper fuel air mixture?
Ive been running headers with no tune for about a year now, with no adverse effects. I do have a SES but its just rear 02's. You might want to check your plug wires if it started running poorly all the sudden.
Good call on the spark plugs , i had some DEI insulator wrap on there but still burnt thru to wire? I seen somewhere on here to wrap the #5 and #7 wires with aluminum foil then put the DEI wrap back on , so i did that after getting new wires and took the family for a test drive , and man i tell ya THATS WHAT IM TALKING ABOUT !!!
Although my truck seems to be running extremely rich , im still loving it ? Time to save up for a tune !
When you turn the key on, you should see your check engine light and you'll know if the bulb is burnt out or not.
Superman09
09-25-2015 05:55 AM
SWINGRRRR
09-03-2015 07:49 PM
