Ebay lt headers.. Problem!
Old 03-29-2011, 04:33 PM
MON_06's Avatar
Default Ebay lt headers.. Problem!
The header is burning my wires from cylinder 5&7 i went to calspeed with jim and i got the msd wires with boots so the wires wouldnt burn but 6months later well 2day the same wires and the boots burn?? Wtf any one else have this problem??
Old 03-29-2011, 04:48 PM
Senior Member
Country Boy's Avatar
The boots are bendable.. bend them out of the way.
Old 03-29-2011, 04:49 PM
Baltimore Whore
Mangled03gmc's Avatar
Roll the dice when you buy cheapy stuff.. None the less it has been a issue, there are some threads floating around, about brackets people have made that hold them wires away from the tubes, so they do not burn.. Just do a search for it
Old 03-29-2011, 05:03 PM
MON_06's Avatar
na the boots dnt bend...
Old 03-29-2011, 05:06 PM
Senior Member
If you have MSD wires, they bend, trust me. Im on my 2nd set and I had to bend them out of the way of the headers.
Old 03-29-2011, 05:29 PM
MON_06's Avatar
the wires bend??..crazy i was just out side trying to c what i can do ill try bending them rite now idk so but ill try
Old 03-29-2011, 05:31 PM
xsports33's Avatar
rock some zip ties... works everytime
Old 03-29-2011, 05:34 PM
2007chevy5.3l's Avatar
I actualy had one of my boots barely touching on one of my runners so i took it off and sanded it down on the belt sander so it wasnt touching.
Old 03-29-2011, 05:38 PM
MON_06's Avatar
i was thinking zip ties also...when i just had slaped on the lts i zipd tied the oem wires but they still wr touching ill c if i can do somthing diffrent with the zip ties
Old 03-29-2011, 05:39 PM
PT's Slowest Truck
budhayes3's Avatar
You burning them by the primary hump? Some guys have made some cool little metal brackets and bolted them to the head, while others have used zip ties, and some use the sleeves that slide over the wires, this has been a problem for years since Dynatech had that design, and is easily remedied
Quick Reply: Ebay lt headers.. Problem!
