Edelbrock intakes?
o hell, lol. JB done went out and baught a 6.0 I been wonderin when that was gona happin. Also, guys i thought u only seen good gains from these vic jr. swaps with just FI? I know u should see some good potential with the nitrous, but what about NA? I wanted to do the same swap a while back to.
youre not procharged or anything are you? reason i ask? is cause of what i think is a CAI tube looks to small ? the mouth of the TB looks alot bigger, i would want this the same size of the tb mouth, the more air taken in the more hp you can produce.
edit: my bad i see the wrapped pipes lol
edelbrock part number 3849
i will have the 4barrel with the NX gemini twin nitrous plate under it soon...i wanna see if the 90mm tb is really gonna be a restriction tho, since i already have it.
11 Second Club
I like the way you're thinking here. I'd like to run a 4bbl on a vic jr as well, but being dbw my options are kinda limited. I'll probably just run an elbow with some kind of stock tb and a 4150 plate(if I use a plate). I would look at different plates other the the NX though. NOS bigshot is a proven performer, speedtech, nitrous pro-flow, and even zex perimeter plates seem to work well with our intake design(to a certain point then the plate itself starts having distribution problems).
