Edelbrock Victor Jr.......I think its the best choice for us truckies
Tin Foil Hat Wearin' Fool
The four barrel tb basically looks like a carb form the top, it has four venturis with four blades. The tb has the same 4150 carb style bolt pattern as the vic jr intake, next the TPS sensor wires MAY be in a different orientation than stock but same plug style. Richard from WCCH will verify once he gets my tb. The IAC should work, just need to rescale the table since the orfice will be of a different size then stock(per my talks with Richard). Richard is doing most of the research and I am paying for the parts Im in the process of finishing up gathering parts to make this work. Maybe Richard will chime in and shed some light on anything I have missed.
Originally Posted by dirt_track_racer_81
sounds good..stick the ole 14x5 air filter on top off my race car...i could only imagin what people would say when they would see something like that
Originally Posted by Rhino79
We may tune the Wood Haulers truck for a Speed Density setup just for that reason....so he can simplifly the air intake.
when CHARRIS got his set up goin i was wondering about that square intake on how that would flow..you would think a round 90 mm tube coming off the throttle body opening up to a square flange would be better but to have something like that im sure would be pretty pricey
you guys are great i'm getting some good ideas to potentially beef up the ole 5.3 with parts i can use after i blow it up and go bigger
everyones got to spend my money somehow lol
