EDIT and instrument clusters
If I were to get a new cluster, can it be reprogrammed by anyone other than the dealer? And if it can be reprogrammed by edit, is there anyone in SoCal that can do that for me?
No ... the dealership can't do it, it's a federal law that they not be able to. When they do cluster changes they have to send the new and the old off to a 3rd party company which does them. You can have these 3rd party companies do them individually as well. I had mine done at AutoCraft Industries of Dallas for 35 bucks I think. There are more than just that one too. Check with your local dealerships .. someone will tell you where to get it done at eventually.
Other than that .. there is nothing else to do to get the tranny temp gauge or the extra 20 on the speedo to function correctly. Just swap them out.
Check around ... there are places that will do it. The dealership should be able to point you in the right direction. I was told they couldn't by about 6-8 dealerships before I found out about the place in Dallas.
They will require you to bring the old one in too, they probably won't go with the honesty policy. It's an easy swap too. pull the dash bezel off, 4 7mm bolts and a plug is all.
