efans dont work??
efans dont work??
efans dont work??
my efans dont work and neither does my a/c?? I went a bought new relays cause about a month ago that was the problem but now after the new relays they still dont work?? but if I open up one of the old relay while it was still on the harness and tap it together the fans will turn on..??? has anyone had this problem?? I dont know if the a/c is a seperate problem or not???
What fans do you have AP? If you want I can come by and look at them. Sounds like the same problem I had with my efans on the crew cab. If its FAL fans. remove the complete fan assembly and check the wiring at the motors.
Oh, and is the ac just flat out not working or is it just blowing hot *** air?
ullose272
07-19-2015 04:14 PM
