EGR Mod q's....
EGR Mod q's....
Okay I hacked that tube running into the intake and now have a quick question about the block off plate...
How large of a hole should I begin with inorder not to set an SES light?
Thanks!
Thanks!
Re: EGR Mod q's....
I used a metal plate between that gasket stuff. I picked it up at O'Reilly and any auto parts store should carry that gasket stuff.
The 1/8" hole was too small and threw an SES light last night. I drilled the hole to 3/16" and heopefully it will be okay.
Does anyone know if the light will reset itself I do I need to go clear it with AutoTap?
Re: EGR Mod q's....
Re: EGR Mod q's....
I just went ahead and disconnected the batt as I can't get my damn USB->Serial adapter to work with this damn laptop from work! I guess it is too new.
I need to get an old cheapass laptop for DTC and EDIT.
Any ideas on how long it takes to reset after the batt is disconnected?
Re: EGR Mod q's....
Couple minutes. I thought you had to pull a fuse or two also.
Well, we shall see after lunch here hopefully all will be okay otherwise I will have to tote my desktop out to the garage and clear it!
