egr port
#22
you can avoid the CEL is you block off all of the ports and everything but leave the assembly stilll plugged into the harness and everything. i drove like that for a week or so and never threw a code
#24
so all i have to do is block off the intake port and the exhaust port and i am done. i had that tube that goes from the exhaust to the intake burn up a couple wires because it was so hot. so do i not have to tune it out now if i block it?
#25
you have to tune it out if you want to be able to remove that whole ugly assembly, but if you are cool with just blocking it off and leaving it bolted to your block and wired up then you shouldnt have to worry about deleting anything in the tune
gmcyukon
10-03-2015 11:03 PM
KINGCYCLES
10-02-2015 10:21 AM
lxcoupe
09-25-2015 12:36 PM
