Electric Fan Conversion
Old 06-26-2010, 03:51 PM
Medic/Z28's Avatar
So how much does this conversion cost?
Old 06-26-2010, 04:06 PM
1Bear's Avatar
While there are always deals to be found, generally speaking, most people pick up the ’05 + OEM fans for around 250 bones and the harness is typically around 100 bucks and then add in what ever someone wants to re-flash your PCM to allow the fans to operate, unless you have the capability to do it yourself.
Old 06-28-2010, 10:17 PM
Majourlittle's Avatar
so you can flash it with HPT, or does it require a tec-2?
Old 07-29-2010, 01:27 AM
Suddog's Avatar
Originally Posted by majourlittle
so you can flash it with hpt, or does it require a tec-2?
^^^^^ x2 ^^^^^
Old 07-29-2010, 04:17 PM
PT's Slowest Truck
budhayes3's Avatar
You need some sort of tuning software such as HPT or EFILive...not sure if the TechII has those capabilities since it is a GM factory bi-directional scan tool and not exactly tuning software...
Old 07-29-2010, 05:29 PM
Suddog's Avatar
Cool so my HPT will turn it on. I was wondering why it had electric fan options on my
ECU (when factory it came with a clutch fan.) GM Rocks!
Old 07-29-2010, 08:10 PM
PT's Slowest Truck
budhayes3's Avatar
Yessiree, you'll be good to go...depending on which harness you decide to buy or make, you can make pin42 control the temp turn on and pin 33 control ac fans, or just go with pin42 and use the compressor clutch wire to trigger the ac fan(s)
Old 07-30-2010, 01:21 AM
Suddog's Avatar
I think I will do the Black Bear harness with alternator over drive pulley. Doesn't seem like a bad deal.
CD82
10-23-2015 07:32 AM
Wrecker 426
09-30-2015 09:39 PM
Silver8ado
09-30-2015 11:42 AM
old motorhead
09-29-2015 08:22 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
Quick Reply: Electric Fan Conversion
