View Poll Results: fueling B1-B2 variances
Truck intake NA fueling variance between B1-B2
38.46%
Truck intake FI fueling variance between B1-B2
15.38%
Ls6/ls1 intake NA fueling variance
0%
Ls6/ls1 intake FI fueling variance
0%
Aftermarket intake fueling variance
23.08%
Im an asshole and I dont give a shit about variances
23.08%
Voters: 13. You may not vote on this poll
Electric fan satisfaction poll
#76
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
1 Post
Originally Posted by LAUST
I have the Flex-a-lite 292 kit for the 5.3 radiator (got it 2 weeks ago), very easy install, I like them a lot.
I went with normal temp activated switches on mine, 1 set for 185 and the other set for 195 (160 stat) I havent had them both kick on yet, the first one keeps up fine so far by itself.
Hasn't seen anything major though yet, just my normal 30 minute stop and go ride to work in 78 degree spring weather.
As far as the install it was great and I like how clean it looks.
Fans
Now I just need to clean up the rest of my compartment
Fans
#77
1 Post
I bought the Flex-a-lite 295 fans and so far so good. I did not, however, follow the instructions that came with the package.
I wired the fans in parallel (neg. to neg., pos. to pos.) and then wired them to the VSC. Also, I did not use the temperature probe, they are running of the PCM. Thanks to Allen and his tune
They work great. I used EFI Live to monitor the on and off temperatures. At about 185 degrees they turn on, and at about 175 degrees they turn off, so it cycles every 5 minutes or so?
When I turn on the A/C, they fire right up.
No complaints here. They work, so I'm happy. Plus I noticed better throttle response right off the bat. No more of that "lag" when I push the gas pedal. opefully I won't have any problems like some guys are saying.
Another thing I didn't like were the brackets that were supplied. I had to cut and modify them to get the fans to stay on solid.
I should've waited for the 292's or which ever kit they just came out with that is specific to our truck, because the 295's are universal.
I will be posting an article, complete with pictures, this weekend.
#78
1 Post
Originally Posted by XLR8NSS
One little gripe about the controller clicking on/off when it reaches the turn off point but, other than that no problems so far.
https://ls1tech.com/forums/showthrea...light=ls1+fans
Note my post that no one either noticed or cared to acknowledge
Wrecker 426
09-30-2015 09:39 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
