Electric fan upgrade
#21
I tow **** all the time with my ls6 denali with the 04+ truck e-fans, hundreds of miles at a time, and it never gets above 200 on the stock gauge. Hell, for that matter, I have never seen it get TO 200 on the stock gauge.
I do have one of those laser thermometer deals, maybe one day when I am bored I will verify the stock gauge's calibration with it.
#22
Not on 1999-2002 models you can't. 2003-2004 can simple enable the E-Fans with a simple flash of the computer. The pins required to operate the e-fans (lo and hi speed) on 2005+ models are not used on 2003-2004 models. 1999-2002 models use the pin to command the hi fans to come on, for the HVAC control ... the pin used to command the lo speed e-fans is not used on these early models. So for those trucks it is not as simple (unless you just tap into the A/C enable). Also, it is not adviseable to flash a newer file to an older ECM, there could be compatability issues.
