Electric water pumps
Old 02-03-2010, 08:00 PM
  #21
Baltimore Whore
Mangled03gmc's Avatar
I am also planing to go with one, biggest reason is that if i puke a belt i can get home before I over heat... I have heard they work fine with the truck acc.. Its like every thing else electric, it can work and it can not work LOL. I will take the risk, hell they have a warr on them..
Old 02-04-2010, 06:19 AM
  #22
eallanboggs's Avatar
In the future you're going to see the serpentine belt go away. Everything will be electric motor driven. WP, PS and A/C comperssor will already be electric motor driven, not just the water pump. You're already seeing electric assist steering. I've have seen Lexus go backwards by doing away with their electric fans and pipe hydraulic fluid from the power steering pump to the radiator cooling fans to spin them. Crazy! This all means you'll only have one short belt to spin the alternator and if they can figure out a way to mount the alternator on the end of the crankshaft where the pulley that spins the serpentine belt is currently located you won't even need that one.
Old 02-16-2010, 12:41 AM
  #23
GFYS and STFU
Spoolin's Avatar
There are remote mounted water pumps that mount on the radiators as well. That's what direction I'm going here this summer with my motor build. That and a belt driven vacuum pump.
Old 05-23-2013, 09:52 PM
  #24
ShredSled's Avatar
Anyone here know if the meziere 300 works with a Katech truck belt tensioner?
Also, if I were to be in the market for a ATI damper, should I still get one for truck engine or vette or f body or what?
Got an LSXR intake for free so I'll be trying to mount that...
Old 06-08-2013, 10:03 PM
  #25
ShredSled's Avatar
Alright, to answer my own question above, the Katech or any other "truck" tensioner will not work. Need one for a car to bolt on to the EWP.
But, now I'm wondering, is there anything else needed for the Meziere 55gpm EWP to hook it up that is not included???
What's up with thermostat???
Also, is there a separate wiring relay harness needed that is not included?
kalikid06
20
10-13-2015 07:37 AM
InsaneDomestics
09-07-2015 09:19 PM
slowswb
09-05-2015 02:27 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
mr03silverado
09-02-2015 11:43 PM
Quick Reply: Electric water pumps
