Engine burning oil
I love Amsoil. Its really expensive (little over $100 every full change) but the extended oil life is insane with this stuff. At 5k miles my oil still has a golden brown color. I change mine around 15k-17.5k miles just when I feel like changing it. Amsoil says I can run it out to 25k oil and filter change but Im pretty hard on my truck and dont mind changing it early.
So your truck isn't burning any oil at all. If you only fill to 5 quarts and need 6 quarts and at 3k miles your showing only one quart low your doing fine but need to add that 6th quart. No need for oil additives.
In equipment that does not burn or leak oil Amsoil in my experience will outlast other oils. I have tested and use a lot of them since 1989-1990 and have found no better performing oil.
There are different strategies that can be used for maintenance based on time, miles or condition based. Using condition based would require testing the oil and there are several benefits to that besides oil life. No matter which type of strategy one picks installing a bypass filter system will save equipment and oil wear while saving one money!
One thing I found is that Amsoil is not expensive when used correctly, way too many people change oil before they need to out of fear, myth, or habit.
Go buy a $4 PCV valve and replace your original with it. I really doubt you need to completely reconfigure your PCV system...
Ive got 185000 on my 5.3 sierra. It dosent use a drop of oil between changes. Ive ran full synthetic since 30,000 and change it every 4,000. My grandpa had an 03 with 75,000 on it when he sold it. And it used a quart between changes. I guess some of the 5.3s had a problem with burning oil that year, or so ive heard.
Noah Burns
09-07-2015 05:50 PM
Ferocity02
07-17-2015 07:05 PM
