engine vacuum
Old 06-05-2010, 04:29 AM
03sierraslt's Avatar
1st off 6-8 would not be your MAP reading. 2nd if reading vac then when its goes into gear the value should decrease a bit however if reading MAP the number will increase a bit. Also i know what your MAP should read if you are really pulling only 8" vac but i want to know what the scanner says it is. I am sorry i dont believe it idles at 8" with a stock cam and idle rpm below 900 and nothing else is being effected. I am not saying you are making it up, i just believe somthing is not right with your setup. Hmmmm
Old 06-05-2010, 04:32 AM
Where is your vac guage hooked to in the intake? Do you still have the stock 1 bar MAP sensor?
Old 06-05-2010, 12:44 PM
marlboroman71818's Avatar
Sorry I dont have the logs to get you the MAP voltage or kpa reading, thats the best I could get you. Maybe Charlie will chime in here with it, also he is the one who verified while doing some tuning. Maybe I can get you some video to help
The gauge is hooked to the vacuum ports on the intake manifold, again Charlie has verified that the MAP reading isnt acting crazy and there are no intake leaks. Yes, still 1 bar and maf. Fixing to move to 2 bar SD.
mhorn0817
07-08-2017 01:54 AM
wrb002
08-31-2015 12:30 PM
eddie_opt
08-12-2015 08:18 AM
jroctpb
08-11-2015 03:52 PM
Quick Reply: engine vacuum
