Et gain?
#21
FormerVendor
As mentioned already your compression ratio is now at the very least right at 12:1 assuming the combustion chambers are now right at 58 cc which you had said.
Just a tad bit high for an everyday street machine IMO.
#22
Is there anyway to lower the compression without swapping the heads? What is a safe compression for a dd ? Should I be ok with a 12:1 with a good tune an lower temp thermostat?
#28
the stock replacements are .051" compressed thickness. You could get some of these in a .060 to take your compression to about 11.7:1 or .065 which will be about 11.5:1
Cometic Gasket - C5751 - Cometic Head Gasket 4.060" Bore - Speed Engineering Performance Parts
