Exhaust on 2500 6.0
Old 02-14-2009, 09:22 AM
ihdude's Avatar
Default Exhaust on 2500 6.0
This is what I'm thinking for exhaust on my 2500 6.0.
Pacesetter headers
2.5 inch non-mandrel bent pipe
Factory cats
Dynomax Ultra Flo X muffler
This is a true dual system. What do you think? Anybody got sound clips of a similiar setup?
Old 02-14-2009, 10:00 AM
wastedrubber's Avatar
why do you want to go down to 2.5 pipe?
Old 02-14-2009, 01:43 PM
neilownz's Avatar
i need to get soemthin done on mine. at least it doesnt have a y down to 3inches like the small engines do i guess. should be possible to cut the stock pipes down and clamp/weld lt's on without too much of a problem...
Old 02-14-2009, 03:40 PM
BigCountryx's Avatar
if you want 2.5 inch, go obx imo. get a set for a 6.0 and weld in you factory cats... all stainless and less fab work.
Old 02-14-2009, 05:58 PM
fish5225's Avatar
If you are planning on running more than 500 hp I would go up to the 3 inch pipe. When I went over 550hp the restriction was obvious. I am currently doing a pacesetter 1 3/4 primaries to 3 inch true duals. I should have it installed in the next 10 days, just waiting on pacesetter to coat the headers. I would be happy to post a clip although we are using magnaflow mufflers.
Old 12-18-2009, 06:48 PM
SPAM HUNTER
2005 Silverado's Avatar
BACK FROM THE PAST.
Will pacesetter headers for my 1500 fit on a 2500?
Old 02-22-2010, 11:32 PM
That's my question too.
Some places don't list the 6.0l but I know it shares parts with the 5.3 and 4.8.
My dad's truck (and soon to be mine) is a 00 2500 w/ 6.0 and 4x4. So will 5.3l 4wd headers work?
Old 02-23-2010, 12:26 AM
neilownz's Avatar
6.0 2500 has stock dual exhaust before the muffler. 5.3 has a y pipe with a single input muffler.
Old 02-23-2010, 01:20 AM
zachm89's Avatar
the headers should work fine, youll just have to get a set of mid pipes fabbed up to run with the dual exhaust.
Old 02-23-2010, 07:49 AM
I'm not worried about fitting after the collectors that's wasy stuff. I just wanted to make sure there were no clearance issues. I know it'd bolt up to the head just the same.
FlowmasterMufflers
10-26-2015 06:19 PM
silverstreak07
08-23-2015 07:09 PM
FlowmasterMufflers
08-17-2015 04:44 PM
Suburban2500
07-19-2015 04:50 PM
Quick Reply: Exhaust on 2500 6.0
