Exhaust
Old 06-19-2005 | 04:43 PM
lo04chevy's Avatar
Default Exhaust
I'm clueless. I have been looking at pacesetters LT for awhile now. Do I use my stock cat aswell? Also, I would like to do a true dual. How do I need this ran?
Old 06-19-2005 | 05:19 PM
Andy's Avatar
Joe, Dont run a true dual... imo
Old 06-20-2005 | 06:13 PM
lo04chevy's Avatar
Ttt....
Old 06-20-2005 | 08:26 PM
OUT2WIN's Avatar
I am awaiting my Pacesetters and I heard you have to get rid of the cats. I am leaving the stock exhaust for now.
Old 06-20-2005 | 08:39 PM
nightmarechevy's Avatar
You can run the off road y pipe and have a section cut out and have a cat welded in. If you want to run true duals you can run a pipe back from each header into the the mufflers, but I would recommend an x-pipe to equal out the backpressure on each side. You can do the same with cats on this setup, just cut out a section and weld one in. The stock cat y-pipe is basically useless after installing the Pacesetters so if you want to run cats you will have to get one welded in somewhere.
flatblack83
03-28-2021 10:28 AM
kha4079
10-29-2018 04:38 PM
blown02408
02-24-2016 04:50 AM
gaps
10-15-2015 02:53 PM
Superman09
09-25-2015 05:55 AM
Quick Reply: Exhaust
