exhaust diagnostics with O2 plug in
Will the diagnostic tool that plugs into the O2 sensor tell me if the cat is stopped up or not working right? I was going to take my truck to the dealer and have them check this to rule it out or in for causing problems.
if it's throwing a service engine code and that code is related to a bank 1 or bank 2 - Sensor 2 then that would be an indication that either the sensor is bad or the catalytic converter is bad. If it's not throwing a code a basic code scanner won't do anything for you.
ARC
57
02-21-2022 11:54 AM
