Exhaust Manifolds
Exhaust Manifolds
Hey i am doing a LS1 swap into my 2002 silverado. I would like to dump the rusted cast iron heads i have with the truck. I need some suggestions on where to get some good exhaust Manifolds.
Thanks
Thanks
Understand, I think that i am looking for a set of shorty headers that would match up with the rest of my existing exhaust system. I am looking for something that would have a little better flow compared to the cast iron.
Could you recommend a manufacture?
Praise The Lowered
BBK part #4005 ...BBK are the only company I know of who use 1 3/4" primarys on there direct fit shorty headers...all the rest are 1 5/8"...If you are wanting to keep your cats in the stock location and stil want performance then I would recomend Bassanni's mid length headers....Good Luck
RibeiroBJJ, thanks for the info.
Does anyone else out there have a suggestions for bolt on headers for an 02 silverado 1500 or know anything about Bassanni's headers?
Long headers? Would they require me to remove the Cats? Would I also have to weld O2 ports in? This is not a big deal just curious the level of work it would take?
no welding required. You unbolt your factory catted y pipe and manifolds and then bolt on the headers and y pipe that comes with the headers and it bolts back to the original exhaust. It already has bungs for O2s. Us its all tig welded and stainless steel. Can't go wrong for the money.
Praise The Lowered
-But I do agree they are a great bang for the buck, and welding oe cats to ory might not be a bad idea,as they are far superior to aftermarket cats and are already "high flow"
