Exhaust Pics ..... and trouble code help
Old 03-22-2008, 02:24 PM
JeevesRules's Avatar
Default Exhaust Pics ..... and trouble code help
getting p1336 since nelson tune .... is that affecting performance?
also getting p0200 injector circiut open code..... what does this mean to me?
almost ready for the track....... Needs bottle or Boost ...... but will mosst likely get a few passes before i decide ......
Truck ran a hell of alot better with open headers as to be expected but need to pass inspection so this is what i went with:
Local Shop cost $200
2 Bullet Mufflers $80
2 NoName Cats $125
2 Reducers $40
Pacesetters .... modified and re-ceramic coated Semi Gloss Black
Old 03-22-2008, 02:41 PM
ZZebes's Avatar
2 NoName Cats $125
2 Reducers $40
You need a crossover pipe
Old 03-22-2008, 03:34 PM
terravast4's Avatar
what are you using for a gas tank??
Old 03-22-2008, 03:37 PM
terravast4's Avatar
sorry, I thought this was a newer truck. Nice set up though.
Old 03-22-2008, 03:55 PM
Banned
Klive's Avatar
agree that you need some sort of cross over, x pipe or something of that nature...
Old 03-22-2008, 04:35 PM
sixltrbtr's Avatar
P1336-CKP variation not learned. You need to do a relearn. P0200- Is the engine missing?
Old 03-22-2008, 04:59 PM
it didnt feel like it was missing ..... but i have 4.56 gears and 3600 stall ..... this engine will see alot of rpms alot of the time, could have happen and i not noticed ........
i am going back to remove the cats after inspection and ill see about an h pipe ..... i have on but thought it would run me alot.
im am using a 16 gallon fuel cell in the bed right now ..... for easy mounting but eventually ill remove the bed and put it in the frame rails .....
Old 03-22-2008, 10:51 PM
sixltrbtr's Avatar
If you have access to a good scanner see if it shows a miss in the misfire data!! P0200 is either a bad injector, bad wires or the computer. Make sure there isn't an injector that is unplugged or not plugged in all the way.
Old 03-23-2008, 09:32 AM
good to know thanks ........ ill pull the injector plugs and check them might pull the spark plugs to see whats going on ......
ARC
57
02-21-2022 10:54 AM
Corvette454l88
09-01-2016 01:24 AM
thunder550
10-08-2015 04:53 PM
chacho44
08-17-2015 03:36 AM
rojeho
08-08-2015 07:20 PM
Quick Reply: Exhaust Pics ..... and trouble code help
