Exhaust Sound After Long Tubes
Jesus I could barely even tell the truck was on lmfao
A4edwin (07-21-2021)
Hello,
Recently finished up cams/heads/headers on a 2003 2500HD with the 6.0. Thanks to everyone who helped with advice, etc.
The exhaust has a strange kind of higher pitched sound to it that almost sounds like an exhaust leak. Here is a video of it: https://youtu.be/TGX7ujBFPNQ
I can't tell if that's just the way it's supposed to sound, or if there's something wrong.
There is a low tone to it, from the muffler, but this higher pitched almost like a ping sound. It's definitely not coming from the engine compartment - I can say that much because when I had leaking manifolds the sound was definitely from inside the engine bay, this seems to be under the car.
Any ideas?
Thanks!!
Any ideas?
Thanks!!
@TXsilverado - no I don't have it anymore, exhaust shop kept it. I'm going back to exhaust shop tomorrow to get it quieter. I'm thinking we'll add another muffler or at the very least a resonator. There's got to be a way to quiet it down without losing performance. For what it's worth, I've done a few thousand miles with the aftermarket muffler drone - it wasn't that bad. I struggled more with my bluetooth FM transmitter as I went through cities.
@68Formula Until yesterday I thought it was a 3.000" but I took it to a shop and they said it was a 3.5 or a 3.250 - I didn't believe them until I really looked at it, and sure enough it's larger.
I've accepted the tinny sound of the headers as just being a byproduct of cheap headers - lesson learned. I may look at wrapping them to reduce sound. Hopefully whatever is done to quiet it down reduces some of that sound as well.
colorado2500hd (06-22-2021)
The following 2 users liked this post by RedXray:
colorado2500hd (06-22-2021),
dantheman1540 (06-22-2021)
Seen OEMs run them before the muffler, after the muffler, and even both. Not sure what the advantage and disadvantages are. Most trucks seem to be after the muffler.
100% Redneck
@RedXray it looks like your resonators are before the mufflers, is that right?
The exhaust shop I’m using said they can’t put resonators in front of the mufflers.
Just got a big one put on basically at the end of the tail pipe, helps a bit with the sound but didn’t quiet it down much
