F-body LS1 heads...any need to do this
Old 01-24-2004 | 12:38 PM
11 Second Club
Default F-body LS1 heads...any need to do this
I was wondering if I would benefit from putting a set of 02 F-body LS1 heads on my 4.8?
or would it be a waste of time?
thanks
Old 01-24-2004 | 02:12 PM
BigKID's Avatar
Unless you are running boost or plan to get them decked to restore you compression ratio, I wouldnt do it.
Old 01-24-2004 | 02:38 PM
silent1's Avatar
thanks
Depends on what you want to do with them in the long run. Stock for stock replacement, I doubt you'll feel any difference. I say this because even though you'll have larger and better flowing valves, you're also dropping your compression ratio. But, if you plan on using them in a forced induction setup, you'll definitely benefit from them IMO. Otherwise I'd say work with what you have.
Old 01-24-2004 | 02:41 PM
11 Second Club
ok thanks guys....
I think I will hold off from buying them
BigKID
07-11-2024 05:28 PM
natejk
11-15-2016 08:05 AM
Dawas
09-20-2015 12:00 PM
FormulaZR
09-14-2015 05:23 PM
gavin2005
09-13-2015 09:04 PM
Quick Reply: F-body LS1 heads...any need to do this
