F.A.S.T. 90mm Intake Swap Progress
#24
#25
14 Second Truck Club
Bluemaxxx TB was junk, kept getting stuck at open throttle. Had to manually shut it. Ordered a 90mm UMI, so I should get it by thursday-friday. I'll post results then. Then on the 9th I've got an appointment with Futral to get it dyno-tuned for the FAST intake. So, I'm pretty excited!
#26
#28
You might need a spacer for the drive-by-wire tb. I actually had to grind a chunk out of the L92 water pump for the UMI TB to fit. It was resting on it and not letting the blade close at idle. I'm not sure how a dbw tb would fit with the L92 pump. Let us know how everything works out!
GrooveCityZ71
08-31-2015 01:05 PM
Gadgetized
07-07-2015 05:40 PM
