Factory fan harness installed... now issues?
Old 06-11-2010, 06:36 PM
  #21
chevyridinhigh22's Avatar
Originally Posted by SnakeOiler
I think your pin 33 is grounding when you turn the on. I believe either the tune is not quite correct or maybe the 2000 can't be tuned for pin 33. I believe people are saying the 2000 can be tuned for this, so maybe look at what could be wrong with the tune.
What exactly did Wheatley tune for you?
Ok my pcm on a cold start or any start for that matter the blue 42 pin is grounded at all times? And my red pin 33 does absolutely nothing a/c on or off does nothing??? What is going on?
Old 06-11-2010, 11:01 PM
  #22
PT's Slowest Truck
budhayes3's Avatar
I'd say one of two things, something in the tune, or the temp input to the PCM...maybe the PCM is getting feedback that the engine is up to fan turn on temp? ie: bad engine coolant temp sensor or shorted wiring from the sensor to the PCM?
Old 06-11-2010, 11:35 PM
  #23
I was thinking the same thing, but the temp gauge works correctly... I dont know if it goes through the pcm first or not. And whats the chances of the temp and red pin 33/ac pressures both acting up... unless this is some crazy coincidence... I guess anythings possible. Wheatley is getting me taken care of so I hope it all pans out for me. Thanks Charlie, you da man!
Any other opinions please post similiar experiences...
Old 06-12-2010, 12:49 AM
  #24
PT's Slowest Truck
budhayes3's Avatar
I was also wondering if the PCM and gauge use the same sender, not 100% sure on that. Do you have access to a scan tool where you could monitor the PCM's interpretation of engine coolant temp?
Old 06-12-2010, 12:52 AM
  #25
No, I need one...
Old 06-12-2010, 01:30 AM
  #26
Truck Sponsor
Wheatley's Avatar
He was just up here the other day,temp sensor was perfectly fine.
I have looked at the file several times thinking I possibly looked over something,everything should be working fine.
I am going to send an 02 0411 PCM,if this doesnt work then there is something else going on somewhere.
Old 06-12-2010, 02:35 AM
  #27
PT's Slowest Truck
budhayes3's Avatar
You thinking that maybe something's shorted in the PCM Charlie? This is a weird problem
Old 06-12-2010, 03:03 AM
  #28
Truck Sponsor
Wheatley's Avatar
I'm not sure,this is not something I run into often at all.Usually everything is straight forward,simple and work great.
Old 06-12-2010, 04:16 AM
  #29
PT's Slowest Truck
budhayes3's Avatar
Nothing like a challenge to keep you on your toes
Bluchevypick
08-18-2015 09:11 AM
mr03silverado
07-17-2015 02:15 PM
skylark
13
07-11-2015 12:54 PM
01sierraon22s
07-08-2015 11:26 AM
Quick Reply: Factory fan harness installed... now issues?
