FAST intake for L92s!!!
Anybody seen this yet?
FAST 102mm L92/LS3 Intake - The intake we have all been waiting for!!!! Set to release Jan 09, Vengeance Racing will be one of the first performance shops in the country to have this intake available. Pricing is TBD. Initial testing shows gains of 14/11 on a STOCK LS3. Vengeance Racing will be testing this intake on several different combos including our 503/449 LS3 C6. Stay Tuned for results and pricing!!!!!
Comp Cam (Fast) has a write-up on the manifold on their website. It's like a 14 hp 11 ft. lb. gain on a stock LS3, I think, so it should produce some good numbers on motors with bigger camshafts. It can take their (FAST) new 102mm TB, (which by the way is cable so it won't be much use on our trucks) as well as the stock 90mm FBW TB and other four-bolt TB's like the FAST 92mm. The only problem I anticipate is that it can't be run on a stock truck accessory set-up because, like the LS3 manifold, it has a lower profile and the TB will hit the upper idler pulley. it would be interesting to see how this manifold performs on a cammed L92, though.
