FAST LSX on Truck
#21
Originally Posted by XLR8NSS
Chuck - Can you get a better picture of how far the belt rides out on the LS1 water pump pulley. It was a concern that since the LS1 accessories sit back closer to the block than the trucks that the truck belt would be pretty far out on the LS1 pump pulley.
Thanks
John
Thanks
John
![Thumb](https://www.performancetrucks.net/forums/images/smilies2/thumb.gif)
![](http://pic2.picturetrail.com/VOL5/758497/3133707/55855335.jpg)
#24
Originally Posted by 02denali
ok what year is the pump you installed and how much for an idler like that one. thanks.
Cost for the idler assembly is not set in stone... But it'll be anywhere between 250-350. Possibly even less in the future if we decided to produce a bunch at a time. How many people would be interested in something like this?
Thanks,
Chuck
#25
Originally Posted by TX_Silverado
Saw that truck when i was up there during the Grand opening both days...thats a helluva beautiful truck i would love to hear it start up and just see the beast run. Awesome Work Chuck
Here is a little recap of what started the project:
2003 Cadillac Escalade EXT -
![](http://www.z71.net/423/EXT.jpg)
Motor:
ARE custom 423 cubic inch forged superstroker
6 liter Iron block
4.040 bore
4.125 stroke
Callies crank
Eagle rods
Ross pistons
ARP studs
Cometic gaskets
Stage 2 ARE 6 liter heads
Comp cam
Dual springs
Comp lifters and hardened pushrods
Rollermaster double roller timing chain
Ported oil pump
and more...
*** click pictures for larger photos
![](http://www.z71.net/423/blocksm.jpg)
![](http://www.z71.net/423/rosssm.jpg)
![](http://www.z71.net/423/head1sm.jpg)
![](http://www.z71.net/423/head2sm.jpg)
![](http://www.z71.net/423/head5sm.jpg)
![](http://www.z71.net/423/head4sm.jpg)
![](http://www.z71.net/423/pis1sm.jpg)
![](http://www.z71.net/423/blo1sm.jpg)
![](http://www.z71.net/423/inst1sm.jpg)
![](http://www.z71.net/423/inst2sm.jpg)
![](http://www.z71.net/423/exh1sm.jpg)
![](http://www.z71.net/423/exh2sm.jpg)
![](http://www.z71.net/423/brem1sm.jpg)
![](http://www.z71.net/423/brem2sm.jpg)
Along with the motor:
FLP Level IV transmission
Yank 2600
ASM headers
Custom true dual 3" exhaust
UPD intake
LS1 Edit
Brembo brakes
FAST intake
Direct port NX
Flexalite 282 fans
#26
9 Second Club/LS1TECH Sponsor
Originally Posted by chucks97ss
I'm not for sure which year the pump is, or if it even makes a difference to be honest.. It is a car pump though.
Thanks,
Chuck
Thanks,
Chuck
That's the advantage of the bolt-on pulley; you can put spacers under it and use longer bolts to get the pulley out far enough to work with the truck accessories.
#27
Originally Posted by BigTex
I've had this project going for a long time now (too long). Most major work was done over a year ago. HPE has had posession of the truck for a few weeks now to finish up the nitrous install. Hopefully, it should wrap up pretty soon.
![Hail](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_hail.gif)
![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
![EEK !!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_eek2.gif)
