FAST LSX on Truck
Old 06-06-2004, 04:04 PM
  #21
Chuck@'s Avatar
Originally Posted by XLR8NSS
Chuck - Can you get a better picture of how far the belt rides out on the LS1 water pump pulley. It was a concern that since the LS1 accessories sit back closer to the block than the trucks that the truck belt would be pretty far out on the LS1 pump pulley.
Thanks
John
Here's a nice big clear one for you
Old 06-06-2004, 05:45 PM
  #22
Formerly one92rs
one03sierra's Avatar
Talking
ok what year is the pump you installed and how much for an idler like that one. thanks.
Old 06-06-2004, 09:50 PM
  #23
Adkoonerstrator
XLR8NSS's Avatar
Thanks for the clearer pic Chuck. Looks like it's on there good enough.
Old 06-06-2004, 10:06 PM
  #24
Chuck@'s Avatar
I'm not for sure which year the pump is, or if it even makes a difference to be honest.. It is a car pump though.
Cost for the idler assembly is not set in stone... But it'll be anywhere between 250-350. Possibly even less in the future if we decided to produce a bunch at a time. How many people would be interested in something like this?
Thanks,
Chuck
Old 06-07-2004, 12:51 AM
  #25
BigTex's Avatar
Originally Posted by TX_Silverado
Saw that truck when i was up there during the Grand opening both days...thats a helluva beautiful truck i would love to hear it start up and just see the beast run. Awesome Work Chuck
I've had this project going for a long time now (too long). Most major work was done over a year ago. HPE has had posession of the truck for a few weeks now to finish up the nitrous install. Hopefully, it should wrap up pretty soon.
Here is a little recap of what started the project:
2003 Cadillac Escalade EXT -
Motor:
ARE custom 423 cubic inch forged superstroker
6 liter Iron block
4.040 bore
4.125 stroke
Callies crank
Eagle rods
Ross pistons
ARP studs
Cometic gaskets
Stage 2 ARE 6 liter heads
Comp cam
Dual springs
Comp lifters and hardened pushrods
Rollermaster double roller timing chain
Ported oil pump
and more...
*** click pictures for larger photos
Along with the motor:
FLP Level IV transmission
Yank 2600
ASM headers
Custom true dual 3" exhaust
UPD intake
LS1 Edit
Brembo brakes
FAST intake
Direct port NX
Flexalite 282 fans
Old 06-07-2004, 01:58 AM
  #26
9 Second Club/LS1TECH Sponsor
Speartech's Avatar
Thanks,
Chuck
Oh it makes a difference! That's a 97-98 F/Y water pump with some good sized spacers between the pulley and the water pump flange. The bolt-on pulley was only used those 2 years; after that they all went to a pressed on pulley that won't work because the belt rides too far out and runs the risk of rolling off the end of the pulley when the engine is running.
That's the advantage of the bolt-on pulley; you can put spacers under it and use longer bolts to get the pulley out far enough to work with the truck accessories.
Old 06-07-2004, 02:43 AM
  #27
Keith's Avatar
Old 06-07-2004, 06:02 AM
  #28
Formerly one92rs
Talking
thanks very much speartech. now i know which one i need to get.
Old 06-07-2004, 12:30 PM
  #29
marc_w's Avatar
That's you and your bud's project truck, right Tex?
jdb11386
12-03-2015 09:34 PM
Three6GMC
11-05-2015 10:02 PM
wrb002
08-31-2015 12:00 PM
black6spdz
07-16-2015 01:32 AM
Deceptarado
07-08-2015 05:24 PM
Quick Reply: FAST LSX on Truck
