Fast lsxrt drivability problems
#102
A friend is gonna sell me a TBSS intake. I'm thinking of getting a nick Williams 92mm tb, do you know if the fast rails work on it? Is the issues with the idle and vacuum problems worth changing to the TBSS or should I stay with the fast102? Oh yeah how's your working out for ya?
#103
Fastest D1 Procharged Truck
im running a nick William's 92MM TB mine leaked at the throttle shaft but im still running it on my TBSS intake seems to be fine.
dont know if the fast fuel rails will work im running a set of stock 07+ ones with a corvette fuel filter since i have the return style fuel system
put the TBSS intake on you'll be much happier i know i am
#104
just curious did you have to install the shallow headed valley cover bolts with fast intake ? i did on my camaro with the fast 92 and i know it will cause issues if they are not changed.
#105
youre making the right move, i yet to see anything come out of the FAST truck style intake! well yeah i did " trouble " i'm pretty sure your injectors will work and fuel rails, i ran aftermarket rails on mine with a fuel regulator .
#108
@reeperz28- yes installed the shallow valley bolts. I didnt have any sealing issues. My problem was thinking I had everything and the install throwing a loop at me. I thinking this intake will do great on a boosted application or bigger cubes.
