Fast lsxrt drivability problems
#21
Man I hope you get this sorted out... The offer still stands to take full advantage of HPT.
My issues ended up being a bad O2 sensor... what a ball buster that was. I need to get my bigger injectors installed, and its not pulling up top like I would have expected. Hopefully the injectors will help with that. I really need to upgrade to pro and get my wideband squared away.
#22
Fastest D1 Procharged Truck
Rob think I might take some logs once I get the truck back together just to see if anyone thinks the tune needs to be adjusted plus I'd like to know what this thing shifts at I have no clue.
I just bought a set of brand new 07+ efans off EBAY and a 34 inch radiator for short money
#28
well comp cams sent me the wrong gaskets what a surprise so now i gotta wait till wednesday till i get the right ones so i can put the intake back together. still havent gotton my e-fans or radiator either and of course the e-fan harness i got is a 2-pin and i need a 1-pin.
but i did get the new crossover tube installed i fits much better then the older style. also installed my 25% underdrive crank pulley from SLP that ive been meaning to put on.
this is the newer style 07+ trucks
this is the older style 99-07 classic
#29
well i got all the right gaskets finally just finished installing the intake and to my surprise
it still wont idle
im beginning to think its something in the tune sucks cause i dont have HP TUNERS or EFI LIVE but i do know someone on here that does said i could take some logs if i needed.
man this **** is getting real old
it still wont idle
#30
Without being able to log with EFI or HP you are really just going to be shooting in the dark now. If you have someone that will help do some data logging that would really help narrow things down.
