Fast lsxrt drivability problems
Old 09-04-2012, 01:04 AM
  #51
N/ALS1's Avatar
Hopefully this gets some resolution.
Old 09-04-2012, 08:09 AM
  #52
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
If putting my stock intake back on doesn't solve the problem only thing left is something in the tune isn't right I'll find out tonight.
Old 09-04-2012, 01:02 PM
  #53
TOTM: June 2007
bgray's Avatar
Did you have the CAI installed in those videos? Sounds like its got an awesome vaccum leak,?
I found my LSXRT video
Old 09-04-2012, 02:25 PM
  #54
Yup I had the CAI on its 4-inch setup sounds like a small child could get sucked up when running lol
Old 09-04-2012, 05:20 PM
  #55
N/ALS1's Avatar
@bgray- what did you do to resolve the leak?
@twolow- did already clearance he intke for he head bolt washers?
Old 09-04-2012, 07:00 PM
  #56
TOTM: June 2007
bgray's Avatar
I had 2 of these lsxrt...both leaked badly.
Sent both to comp cams, both bases were badly warped. They fixed them and sent them back. I returned the one and kept the other, still havent installed it as i have no faith in them.
Old 09-04-2012, 07:26 PM
  #57
N/ALS1's Avatar
Damn im in the middle of an install and now im worried. Truck has been torn apart due to my daughter being born and couldnt work on it. I will install it and try to blue rtv seal every gasket possible. The only problem I see with mine is the purge solenoid, but will fix that with jb weld as I dont think it is really that stable and pose a leak.
Old 09-04-2012, 07:58 PM
  #58
N/ALS1's Avatar
Bgray are you on youtube sporting bassanni mufflers?
Old 09-04-2012, 11:00 PM
  #59
well guess what i put the stock intake back on truck runs tittys i also noticed the intake dosent make so much noise either
and yes N/ALS1 i did notch out the intake for the head bolts
im kinda thinking the TB is to big think i might try putting the stock TB on the LSXRT and see what happens.
Old 09-04-2012, 11:07 PM
  #60
N/ALS1's Avatar
Damn I wonder if I should've got the 92mm fb now. But I hope I have some good luck with mine.
Quick Reply: Fast lsxrt drivability problems
