Fast LSXRT ordered
Old 02-02-2011, 12:25 PM
  #161
Resident Retard
BlackGMC's Avatar
Originally Posted by hirdlej
That's on a NNBS truck and it looked like poops. I want to see Charlies
It will look like poop on ours too if you dont do something with it. Burn a couple of calories and take OFF the tubing and tape and reroute it. I did it a long time ago when i swapped on the ls6 intake. I only had to cut 1 wire to lenghthen it. Now everything is out of the way. I cam have the intank off easily i. About 5 mins. Well worth it and easy to do just takes some time and looks 100% better. But to each his own.
Old 02-02-2011, 01:11 PM
  #162
TXsilverado's Avatar
the truck harness can be moved to look better
Old 02-02-2011, 02:24 PM
  #163
Resident Retard
BlackGMC's Avatar
Here is mine
Before
in the middle
Finished but missing wire covering, i never got pictures after i put the covering on it.
Old 02-02-2011, 02:31 PM
  #164
caddy03pimpin's Avatar
Here are some of mine as well... I turned the fuel injectors around to hide the connectors and rewired the loom for the coil packs and tucked in the large wire loom by the fuel rails. It is not that hard to do and I think it looks way better than before..
Old 02-02-2011, 03:11 PM
  #165
pewterliftedz's Avatar
Originally Posted by BlackGMC
This is about where i would start panicking haha...
Looks good corey..
Old 02-02-2011, 04:13 PM
  #166
skolman91's Avatar
when did you have the ls6 intake? and im guessing you didnt like it since its still not on there..
I remember the dorman, and tbss you did, but not that. Geez that means the Fast will be the 5th intake you've dealt with, you should have some input on this by now..
Old 02-02-2011, 08:42 PM
  #167
Resident Retard
BlackGMC's Avatar
I tried it out awhile ago. I was still learning how to tune so the gains could have been better. Yep i usually dont keep mods if they dont perform. 3 intake swaps, 3 cam swaps, 2 header swap, i lost count on exhaust setups.
Old 02-02-2011, 08:50 PM
  #168
Rick_Vor's Avatar
Here is mine]
What an improvement. Now I know what I need to do next time it's too stormy to work outside.
Rick
Old 02-02-2011, 09:46 PM
  #169
Truck Sponsor
Wheatley's Avatar
It does look better tucked away,mine doesn't bother me though
Old 02-03-2011, 03:21 AM
  #170
Truck Sponsor
Wheatley's Avatar
Here are a few pics.I am about to order the fast billet rails
Quick Reply: Fast LSXRT ordered
