Fast LSXRT ordered
#161
Resident Retard
It will look like poop on ours too if you dont do something with it. Burn a couple of calories and take OFF the tubing and tape and reroute it. I did it a long time ago when i swapped on the ls6 intake. I only had to cut 1 wire to lenghthen it. Now everything is out of the way. I cam have the intank off easily i. About 5 mins. Well worth it and easy to do just takes some time and looks 100% better. But to each his own.
#164
Here are some of mine as well... I turned the fuel injectors around to hide the connectors and rewired the loom for the coil packs and tucked in the large wire loom by the fuel rails. It is not that hard to do and I think it looks way better than before..
