Final Dyno Numbers for the 4.8L
Old 10-18-2004 | 01:08 AM
  #21
Cmarsh93z's Avatar
Good numbers! I tuned a 4.8 with a 214/214 cam, and it made ~ 279rwhp at a very conservative A/F. Your truck is making good power
Chris
Old 10-18-2004 | 01:23 AM
  #22
Wheatley's Avatar
Truck Sponsor
Dan those number are bad *** man,even though I was there,that thing is crazy,I know you can hit 13's man
Old 10-18-2004 | 02:53 AM
  #23
blk03's Avatar
looking good Daniel.
Old 10-18-2004 | 07:10 AM
  #24
one03sierra's Avatar
Formerly one92rs
Talking
well according to nx the 125 shot is what the power is suppose to be at the wheels. the shot at the engine will actually be more. the torque will be hard to figure out.but the hp will be around the 270ish area.im running a 150 shot. so at the flywheel for example it is near a 175 shot.
Old 10-18-2004 | 09:55 AM
  #25
leochevy2001's Avatar
Those are good numbers Daniel. I want to see what the truck will run once you get the miles on the tune. My offer still stands
Old 10-18-2004 | 10:37 AM
  #26
BigKID's Avatar
Originally Posted by 01 Thunder
my peak HP is right near 6,000 rpms.
the graph levels out right there.
my Tq peaks at 5,000 rpms..
Where does it start falling though? (Hp and Tq)
Old 10-18-2004 | 05:52 PM
  #27
ThunderZ28's Avatar
12 Second Club
Kenny,
Hp doesnt fall. it actually looks like it is still rising, but ever so slightly.
Tq starts falling off at @ 5,000 rpms, and by 6,000 rpms it is at 247ish.....
Old 10-18-2004 | 06:07 PM
  #28
Originally Posted by 99silveradoSS
I know that CARAZYCUTER4.8's truck has the 212/218 cam putting out 285+
01 Thunder: Good numbers! I bet that cam has a ton of under the curve hp/tq. What are you shifting at with it?
Last weekend I had 289 rwhp with 22 degrees of timing & 390 rwh with 401 ftlbs of torque on the bottle. I hit 289 with with 32 degrees of timing, & 2 hours of wideband tuning on the hwy with the z06 cam. I made the same with the comp 212/218 cam with 22 degrees of time with much more usable hp. I would bet I could have hit 300 + on a-cold day with unlimited dyno time. after I put the bottle on it I backed the timing down to be safe, with the new valve springs & some extra timing I could have gotten more. it makes power through 6400 rpm's.
Old 10-18-2004 | 06:17 PM
  #29
ThunderZ28's Avatar
12 Second Club
Originally Posted by CRAZYCUTER4.8
Last weekend I had 289 rwhp & 390 rwh with 401 ftlbs of torque on the bottle. the 289 was with 32 degrees of timing, & 2 hours of wideband tuning on the hwy. I made the same with the Z06 cam though it just had NO to torque!
so what do you run off the bottle????
great numbers by the way
Old 10-18-2004 | 06:24 PM
  #30
corrected info with thread above. I would bet the ZO6 cam would have been a better nitrous cam, wider lsa & more lift
